Hi! New here but have read the forum several times.
I recently made a backup of a DVD-5 I have through the help of one of the guides found here.
The picture quality and sound quality are terrific, and all menus/extras, etc. are functioning properly.
When played on my set-top player (Philips DVD953. I also have a Philips DVD701 and a Panasonic Portable Player LV-55 I think. The discs play fine on those too but have the problem that I am about to mention.), the discs play fine for a few minutes, sometimes several. Then, they will skip a little, display a little blockiness, or sometimes freeze (can use FF or REW to play again). The video is fine, since when I run over the parts that skip again, they play flawlessly.
I used some cheaper DVD-R's from SmartDisk.
Also, sometimes the player will glitch a bit with regular DVDs (it is used frequently).
Could some higher-quality media or a DVD lens cleaner do the trick?
My DVD-R/RW drive is a Pioneer DVR-104, if that helps.
Thanks in advance!
-J.P.
You have answered your own question:
Cheap disks don't always record properly (there are tons and tons of messages/complaints across ALL boards like this one).I used some cheaper DVD-R's from SmartDisk.
Bite the bullet and go buy some quality name brand DVD-Rs (Verbatim is relatively cheap), and repeat your original test. With good media, your DVD-R should work just like the original.
NO DISC on set-top players - dvd replication
By wzt in forum Authoring (DVD)Replies: 16Last Post: 25th Sep 2009, 11:15 -
setting up dvd / tv / set top box??
By wundahoss in forum DVD & Blu-ray RecordersReplies: 1Last Post: 5th May 2009, 13:48 -
DVD/Divx/USB (2.0preferably) set-top players
By celchlepp in forum Newbie / General discussionsReplies: 20Last Post: 13th Mar 2008, 17:10 -
Subtitles wont/don't display on set top players
By scamuel in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 24th Jan 2008, 08:31 -
Choppy playback on set-top players only...
By Anonymous4374945 in forum Newbie / General discussionsReplies: 1Last Post: 26th Dec 2007, 14:51
