I want to use Virtual Dub to edit an AVI I captured by using its internal filters and then saving the edited AVI as uncompressed to be encoded later to RM. The edited AVI plays fine in Windows Media Player for the first few minutes but if I seek ahead to about 5 min, I get an "invalid file format" error, yet I can still see some of the frames. When I try to encode this "corrupted" AVI into RM with Real Producer, RP only encodes the first few bit of the clip and stops. In VDub, Audio is set to direct stream copy mode and audio interleave is on. Has anyone come across this problem ? I used both 1.4d and 1.4.5 and both have the same problem.
Hello!
I have the same problem.
I know how you can "overtake" the problem, but it is a boring work.
Instead of you delete that frames you don't want, I suggest you save that frames you want in 'n' files and join them into a new file.
Therefore, I also want a GOOD solution for this problem.
So, if you discover any, please tell me.
Thanks. -
Anybody know how u can remove the NB that is in the left hand side of all the .avi's i d/l?
Use Virtual Dub and the logo away filter. Do a search for it in the forums. Actually I'll save you the time, here's the thread:
http://www.vcdhelp.com/phpBB/viewtopic.php?topic=36872&forum=4
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
Please disregard this post. Thank you. -
Hello!
I've just discovered the problem.
If you edit an AVI file in VirtualDub and the resultant file is greater than 2GB and you are using Win9x, the problem occours. I think the solution is upgrade OS to Win2000 or other without filesize limitation.
I hope it helps you.
mencoder AVI: invalid audio stream ID: 128 - ignoring (nosound)
By dialallama in forum Video ConversionReplies: 3Last Post: 4th Mar 2009, 08:17 -
Apple Quicktime HDV to AVI,or at least a windows compatible editing format
By SuperDre in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 2nd Mar 2009, 14:58 -
Exporting AVI from Premiere in exactly the same format as imported AVI?
By JulieCat in forum Newbie / General discussionsReplies: 4Last Post: 8th May 2008, 10:16 -
Editing an AVI file so I am just left with the VIDEO Avi (No Audio)
By incrediblej in forum EditingReplies: 6Last Post: 26th Mar 2008, 19:16 -
question about "save old format avi" with Vdub
By mr-scarface in forum EditingReplies: 3Last Post: 5th Sep 2007, 21:34
