With the last part of the cutting TMPGEnc freezes at the end of producing the audiostream. The first part runs fine and gives no problems. What can be going wrong.
I'm assuming you're cutting a MPG file.
You may want to run your MPG file thru VCDGear or similar programme to correct any errors in your MPG file. TMPGEnc is very sensitive to MPG errors.
Also, TMPGEnc seems to stop after extracting the audio portion, but what it's really doing is remuxing and creating headers. You may want to wait a few minutes to see if that is the case. If your computer is truly frozen---no mouse movement, etc., then this is not the case.
Cutting MTS: splitter problem
By cheerful in forum EditingReplies: 3Last Post: 6th Jun 2012, 19:26 -
Virtualdub kernel32 error, TMPGEnc cutting video
By koberulz in forum Newbie / General discussionsReplies: 5Last Post: 11th Apr 2012, 11:36 -
subtitle problem after cutting commercial from video
By satish_j in forum SubtitleReplies: 4Last Post: 25th Nov 2010, 00:51 -
Little problem-Cutting Scenes-Ideas?
By n3ur0 in forum Newbie / General discussionsReplies: 1Last Post: 17th Mar 2010, 08:44 -
TMPGEnc DVD Author 1.6 cutting a movie short?
By FizzFozz in forum Newbie / General discussionsReplies: 0Last Post: 21st Jun 2008, 11:20
