  1. First sorry if this is on the wrong forum.
    ok I have a couple of films in DIVX, using the very latest divx bundle (5.0.2) divx 2.0
    I am also using TMPGEnc to convert the films into mpeg format to make into a SVCD (to watch on my dvd player, bigger screen and all that)
    The problem I have is I keep getting errors, I use the guide from this website but keep getting errors popping up, basically showing lots of numbers and all I can do is click ok?
    This does not always happen but as or yet I am unable to convert a divx movie so I was looking for some advice/help?
    thanks
    Darkish
  2. Banned
    Jun 2001
    UK
    Did you scan the AVI for junk frames ?
  3. I believe I did, I downloaded the "divxfit" tool and ran that before trying to convert it. I did however come up with a error about the Stream? which I was unsure of, after I tried to run it again i ended up with the usual -number errors and had to abort the conversion.
    thanks for the reply.
  4. Found a post that releates to my problem, sorry about this and cheers, hopefully can get this sorted now
    Darkish
