  1. i got the 3 spiderman SVCd mpeg2 parts and i want to make them 1 file avi so they take up less room i've tried a bunch of things. I have a 2.11GB joined moive. i used joiner to join the parts. I can't skip to any part of the moive, but i think thats because the file is so big. SO i want to convert it to AVi. i have Vidomi and it says "encorder failed to inalize proeplery" and virtual dub says there a "pack synroniztion erorr" WHat do i do and if you could get me simple program that will work or help me fix them so they will convert of one of thoses programs that would be awsome!
    e-mail : phillyfan225@comcast.net
    AIM: Phillyeagle just say you saw my message and will help me out
    Thank a lot
  2. Banned
    Jun 2001
    UK
    Have you tried TMPGEnc ?
    File > Output to File > AVI
    You can even select a codec to use
    You may need a good mpeg2 codec, if it wont load. Install PowerDVD 4, then it provides the codec for use in TMPGEnc.
  3. I'm geeting an erorr saying file unsupported. I have DVD2AVI but when i do that the picture is squished. Does that matter in the end? What do i do and HOW!!!! im kinda computer dumb sometimes thnaks
  4. Member spidey's Avatar
    Apr 2001
    U.S.A.
    see your other post. Please don't post the same thing multiple times
    ~~~Spidey~~~
    "Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards
  5. Banned
    Jun 2001
    UK
    What program is saying that ? TMPGEnc ? if so do you have a prefer mpeg2 codec installed ? Like I suggested with PowerDVD
    If your picture is squashed, then your not maintaining the aspect ratio, check your settings for full screen keep aspect ratio
  6. ok how do i check my aspect ratio so it fits and isn't squished and do ifix it in DVD2AVI or the TEMPGenc??? THnaks
  7. Banned
    Jun 2001
    UK
    1, Load SVCD template
    2, Settings > Advanced
