forgive me if this is a stupid post,![]()
i've got a winTV Go - card running in win2k.
when i open virtual dub in capturing mode,
there is image & sound,
but when i try to capture the video (according to the capturing guide that is posted here),
and play it afterwards,
there is no sound...![]()
does anybody know what might be the problem?
thanx for helping me out...
jojo
Ok, sounds dumb, but it worked for me. Go to the aduio tab in capture mode. Is the sound meter moving? It should be if you hear sound. Now go to capture. When I do this first, I get sound. Good luck.
Actually that is dumb. Just because you can heard sound and see it moving in Vdub's audio tab doesn't mean you're actually capturing that sound.Ok, sounds dumb -hokie91
jojoplato,
Accessories > Entertainment > Volume Control
In Windows Volum Control
Options > Properties
Under
Adjust Volume For
[ ] Recording
Dot the circle next to recording and in under the box
Show the following volume controls:
[ ] Line In
[ ] Microphone
Put a check into whichever input your WinTV's audio out cord is plugged into, usually the Line In; Hit Ok and then you should see the Recording Volume controls for the Line In or Microphone.
Under the slider bar for your Input there is a
[ ] Select
box, check that and then close the volume control app
Then when you go to Virtual Dub and capture you should be capturing from the Line In or Microphone, depending on which input you are feeding the WinTV's audio too. -
deadpac,
thanks for the reply.
Everything worked as you said.
but:
* it only worked when i put the sound-input from my video, into the mic-input from my soundcard. It doesn't work when i put the cable into the Line-in spot...
* now i can capture sound & image, but the sound is very very crappy
, compared to the original sound. Any ideas what might be wrong here???
thanks
jojo
problem with compression using virtual dub
By jpez1 in forum Video ConversionReplies: 4Last Post: 3rd Aug 2010, 14:24 -
No Sound With Dazzle DVC100 using Virtual Dub
By kpoman in forum Capturing and VCRReplies: 3Last Post: 3rd Nov 2009, 09:35 -
Virtual Dub problem
By rocka in forum EditingReplies: 3Last Post: 2nd Jan 2009, 04:46 -
Simple Virtual Dub Problem...
By tetzy in forum EditingReplies: 2Last Post: 22nd Feb 2008, 20:49 -
how can I specify the resolution when capturing in virtual dub?
By Onceler2 in forum Capturing and VCRReplies: 3Last Post: 28th Jan 2008, 11:11
