Can u help?
i have a film ((Shrek (DVD RIP - SUPER HIGH QUALITY - NO SUBS).avi.
it plays on my computer but can't get it to convert to mpg.
has anyone had the same problem??
I have tried TMPGEnc and the file is to big for nero to do a straight
burn.
thanx![]()
You cant get it to convert , Why ?
You tried TMPGEnc to convert it ?, What happens ?
The file is too big for Nero ? The AVI ?
Since we don't know what your problem is, we have to guess. Then having guessed at just about everything, we usually find out its something more simple. So start by telling us what the problem is.
Shrek is getting on a bit now, I did download that AVI many months ago and made a VCD, so more info please.
Tips
Load into Vdub scan for junk frames
If Vdub complains about the audio, save the audio out as a WAV, which could be AC3 and needs to be converted later. This WAV can then be used with TMPGEnc
Make sure the DirectShow priorities are set higher a value of 4 works well
Well that's the short version
AVI to DVD Question
By Cyberian75 in forum Video ConversionReplies: 2Last Post: 8th Jul 2010, 19:06 -
question about avi files
By tlrbjc in forum Newbie / General discussionsReplies: 5Last Post: 17th Jul 2009, 13:54 -
For VOB files to AVI, I use avi.net . . Question
By nhbfan12345 in forum DVD RippingReplies: 4Last Post: 10th Sep 2008, 23:02 -
AVI ---> DVD question
By arcticmoonshadow in forum Newbie / General discussionsReplies: 2Last Post: 2nd Mar 2008, 21:40 -
AVI file question
By jImMy_JaZz in forum Newbie / General discussionsReplies: 1Last Post: 9th Feb 2008, 15:03
