I am having problems with my vcds. I had burned two and they worked perfectly and I tried 2 different more both had sound but the video was not there if anyone knows what is wrong please let me know I would greatly appreciate it!!!!![]()
Results 1 to 9 of 9
More guess work here, start by telling us what you have, what was used to convert and what was used to burn.
The movie is austin powers 3. I tried to just burn it w/ nero and when I played it on my standalone I just get the sound and not the video. i tried to convert it w/ tmpgenc and it wouldn't play well with WMP. Before i did the conversion it played on WMP. If there is anything more you need to help out let me know.Thanx
Ok, Gold Member. So you downloaded an AVI and you have verified its not a fake ?
If you cannot see the video, then it could be you don't have the correct codec installed, however TMPGEnc may need an adjustment before you can view it.
TMPGEnc VFAPI (Download from TMPGEnc site)
Select options > environmental settings
click the VFAPI plug-in tab
right click the "DirectShow" and select higher priority, do this several times until its at the top with a value of 4
When you do the above, click preview to see if you can now see the movie, if not install the Nimo codec pack (There is no sound in preview)
I took your advice and tried everything. I burnt a vcd and now I get sound and video but the video flickers all over the screen. How do I correct this problem?
When you used TMPGEnc did you hit the load button a and load a VCD template ? PAL or NTSC
When I had TMPGEnc I loaded a PAL template and when I tried to burn it I did PAL format. Should I try it with NTSC?
Well what was the original quality like ?, NTSC if your in the USA, PAL everywhere else
Most DVD players will play NTSC, but not all TV's will, make sure yours do if you want to try NTSC
Difficult to explain (sorta) computer problem
By Heywould3 in forum ComputerReplies: 10Last Post: 9th Nov 2011, 11:48 -
Sony CEO says internet piracy killing movie biz
By deadrats in forum Off topicReplies: 15Last Post: 14th Nov 2009, 19:42
