  1. K, I have an OGM file, I already know how to take out the audio and video out of OGM file using GraphEdit, but I dont know how to extract the Subtitle so I can take it out and actually embedded directly to an AVI file.
    I cannot just Subtitle > Input > Output File it to an AVI file since eveytime I use it, it gives me illegal function on Windows Player 6.4. (SUBTITDS.AX). And BSPlayer is just bad, with illegal functions even if you go back to a any point in the movie). But if I can get it out, I can use VirtualDub and have it embedded permanantly without any probs.
    Anyone have any ideas?
  2. Well, had no success in taking out the srt file from the OGM file that have the subtitle muxed. (When playing OGM file, subtitle can be switched on and off). So I just Opened the OGM file in GrpahEdit and...
    Final.ogm > Ogm Splitter > Subtitle > AVI Mux > Final.avi
    Play
    Then Open again in Grpahedit.
    Final.avi > AVI Splitter > Final.txt
    Final.txt is a DUMP (dump.ax) Filter
    Open it and all the subs are there, though it only has the Subtitles all in clear line by line, but the timing for it has to be done manually since they are lost. Its a good project if doing by SSA to make your own Script.
    Thats all I can do unless someone has a better way of taking subs out of a OGM file.
    __________________________________________________ ___________
    The > sign represent joining the lines in GraphEdit.
    Open the Final.txt with wordpad or winword, opening by Notepad does not show the lines in order. Its all messed up in notepad.
