Hi i want to convert a AVI to mpeg
now simple as that sounds, when i convert it with TMPGenc it mutates the video so that its in a different resolution
The AVI is at a weird resolution but I want to keep it at that because otherwise it will be out perspective/ratio/whatever.
I have two AVI's of different size.. don't mind which one i convert aslong as i can get one of them to mpeg at the same size..
408*228
and
444*248
any help/ideas?
If you explain why you need to convert an avi to an mpeg, we might be able to help. 8)
Most likely you are using "4:3 Display" and "Full screen (keep aspect ratio)" as your source aspect ratio in Setting.
I can't quite remember what you should be using, but give "FS (kar)2" a try instead. Just fiddle with each of the settings until you find that the image in the encoding window has black bars top/bottom, and make sure that the image isn't still stretched too far either horizontally or vertically - just as long everyone doesn't look too fat or thin.
If you need anymore help, give us a buzz.
Converting to avi keeping same screen size
By Dungogvolts in forum Video ConversionReplies: 18Last Post: 15th Apr 2012, 21:57 -
Delete commercials keeping the right timing of the subtitles on a MPEG TS?
By edea in forum DVB / IPTVReplies: 4Last Post: 21st Oct 2011, 18:19 -
How to make an AVI better quality (keeping output still as AVI)?
By Dogpoundz in forum Video ConversionReplies: 15Last Post: 22nd Sep 2011, 01:12 -
Converting DVD to AVI - keeping subtitles
By Matthew1404 in forum DVD RippingReplies: 2Last Post: 11th Mar 2011, 17:48 -
[Help] avi to wma keeping avi quality?
By Riddick51PB in forum Video ConversionReplies: 4Last Post: 26th Jun 2007, 19:13
