When i finish using DVD2AVI and start converting it in TMPGEnc it says that the file is unsupported. Can any one shed some light?
Thanx
oh also it is both audio and video that say they are not supported.
dvd2avi.vfp is in the same directory like dvd2avi.exe
TMPGEnc.vfp is in the same directory like TMPGEnc.exe
run TMPGENcVFP_INSTALL.bat
check TMPGEnc vfp is registered to VFAPI (TMPG>option)
check VFAPI plugin (dvd2avi>help)
TMPG> option> enviromental setting> VFAPI> check dvd2avi project file reader and/or select a higher priority.
Do not delete the .vob files. Do not move the .vob and / or .d2v unless you want to edit the .d2v manually.
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 15:42 -
What is the different between TMPGEnc Authoring Works 4 & TMPGEnc 4.0 XPres
By c1steady in forum Newbie / General discussionsReplies: 0Last Post: 28th Apr 2010, 21:32 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 13:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07
