First of all I'm a newbie as you can see in the subject and I have been reading the guides here on the left but I'm still in trouble so I seek your advice.
I just bought a Pioneer 104 and was trying to do my first DVD-backup. I ripped the movie with SmartRipper 2.41 (all files, not just the main movie). The whole DVD is around 4.11 gigs. Then I opened video_ts.ifo file in IFOedit V.0.91 and pressed the get vts sectors and saved the ifo files. Next I closed ifoedit and opened it again and pressed the dvd play button, then i got this error No valid DVD-video volume could be located. But I pressed ok button if I would proceed, then it played some logo from the movie company and stopped and the status says Title Set Menu.
So any help here would be nice.
Thanks in advance.
It is fine, you can burn it with Nero. I believe if you rename your folder into VIDEO_TS it will work fine.
That error message occurs if you don't have a DVD in your drive. Just ignore it
I'm not sure why the menu didn't load in IFOEDIT (after the company logo screen) when you pressed the dvd play button. It should work just like the original DVD if you ripped everything. Try loading the .ifo file in WinDVD (or whatever software DVD player you use) and see if it plays ok.
I need IFOedit for Mac
By bryceguy in forum MacReplies: 7Last Post: 14th Dec 2011, 11:45 -
You want newbie? This is newbie. Watch VHS movies.
By Mighty Melvin in forum Newbie / General discussionsReplies: 14Last Post: 12th Oct 2009, 08:43 -
ifoedit question
By J. Baker in forum Newbie / General discussionsReplies: 3Last Post: 17th Sep 2007, 03:10 -
IFOedit question...
By Djard in forum Newbie / General discussionsReplies: 6Last Post: 4th Aug 2007, 00:42 -
adding CC with ifoedit
By loster in forum Authoring (DVD)Replies: 0Last Post: 9th May 2007, 19:15
