Hi all, great site.
I have just bought The Time Machine and would like to put it on Disc.
I am trying to convert it from Region 1 to Region 2 can anyone help me on how to do this as i have tried everything i know.
Thank you
Danny
Just make it region free when you rip it with smart ripper/ dvd decrypter etc then it will play on all machines
Thanks for the reply spooki
I did try that but got big lines going acroos the screen, would changing the frame rate sort this? or anything elseDanny -
For all intents and purposes, region 1 is NTSC, region 2 is PAL, and it is likely that the disks follow suit. While your PC can correctly play a rip of either, your DVD player and TV might not, unless they are both dual standard. Ripping should make the rip regionless, but there are still the broadcast standards to deal with.
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
Playing a Region2 dvd on a Region1 Player
By barbudo in forum DVD & Blu-ray PlayersReplies: 2Last Post: 17th Feb 2011, 08:48 -
PS2 and DVD info from region1 moving to region 2. confussed totally here
By joelliott in forum Newbie / General discussionsReplies: 7Last Post: 14th Dec 2010, 15:52 -
entire disc rip Drilbit Taylor Region1
By greenapple in forum DVD RippingReplies: 1Last Post: 13th Jul 2008, 03:09 -
Region1 disc... need to backup to region 0
By snadge in forum DVD RippingReplies: 11Last Post: 1st Mar 2008, 13:25 -
Region1 discs playback problem
By efiste2 in forum Newbie / General discussionsReplies: 12Last Post: 29th Oct 2007, 12:43
