Sorry to bother you with this but, I encoded an avi to svcd and when it finished converting the file size was over 1 gig. Is there any way that I could break up this mpg to fit it on 2 cd's?
You can use TMPeg to split the SVCD using the tools. I perfer to demux with TMPeg and then cut and mux with bbmpeg. You don't get loss of sound sync that way. Proceedures are in the EDIT at left.
NOT so sure about SVCD but I use JIAO VCDCUTTER to chop up all my MPEGS.
You can download it from
http://www.seller-club.com/~vcdcut/vcd403.zip
however I have had loads of problems with version 4.03 - even a legit copy won't chop properly - only get the first seven seconds just like the demo. Try it and see though.
however version 4.01, http://www.zdnet.co.uk/software/fstore/9/0/001090.html
does it no probs - although obviously it doesn;t have as many tools as the newer version, but it and "cracked" versions are widelty avbl.
Hope this helps
scattergun
How can I convert MPG file recorded by progDVB into a regular MPG
By Aafour in forum DVB / IPTVReplies: 8Last Post: 16th Oct 2008, 13:51 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 14:48 -
VC-1 to Mpg-2 and MP4-AVC to Mpg-2
By Bruce Kuhn in forum DVD RippingReplies: 6Last Post: 10th Jan 2008, 17:06 -
Convert DVD TO MPG OR VOB TO MPG FOR FREE!!!!
By beetee123 in forum Video ConversionReplies: 9Last Post: 27th Jul 2007, 08:47 -
Spliting large mpg file into clips and saving each clip as a mpg file ?
By denise4gb in forum EditingReplies: 1Last Post: 6th May 2007, 17:52
