Hello Helpful People,
I hope I'm putting this message in the right place-- apologies if this is the wrong forum.
I am about to build a new computer system and I want to be able to
rip and convert DVDs to VCD. Do I need to get a particular kind
of video card in order to do this? I don't have a digital cam or
anything like that, so I don't think I need a capture component on the
card-- or do I? Would I be able to do everything related to ripping,
editing and converting with an ATI Radeon 8500LE?
Please advise me! I'm confused![]()
Thanks for your help,
Baffled
you dont need any particular type of video card to rip dvd's to vcd. as long as it works and you can see your screen its ok. hope this helps
Maybe, but...
Here goes the explanation of my answer:
There are two main ways of getting that movie to VCD:
- Ripping: This is what you are referring to in your post. The process is basically, copy dvd files (vob's) to hard drive from dvd-rom, massage it, re-encode to VCD specs, burn to CDR(W). So, other than being able to see the programs (and to boot your pc) you do not need a capture card whether it has a tv tuner or not. Any regular video card will do.
Results: very good to excellent
- Capture: This is taking the dvd and playing it on a standalone DVD player and capturing the video to the hard drive. This will require a card, not necessarily part of your video card, that can capture video. Much like recording to a VCR. If not captured directly to VCD specs, then you would treat it like a rip and use the same process. I think its safe to say that people who use this method capture directly to VCD specs for the time savings.
Results: good to very good
Also, don't forget to look at the 'WHAT IS' and 'HOW TO' sections for some very excellent and specific help on what you're trying to do. Everyone has their reasons for their own methods of re-encoding and capture. Find the one that best fits your ability, time, and patience.Have a good one,
neomaine
NEW! VideoHelp.com F@H team 166011!
http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
Folding@Home FAQ and download: http://folding.stanford.edu/ -
Ooops... Subsidiary question.
Ripping will work with any DVD-rom drive, right? I'm looking at getting the Lite-on 16x... This shouldn't create any problem should it?
Thanks again,
Baffled
Using an Onboard video card with a PCI video card
By Nastydave in forum Media Center PC / MediaCentersReplies: 3Last Post: 6th Apr 2012, 02:37 -
[VHS conversion] Sound Card, Video Card?
By bessiecat in forum Capturing and VCRReplies: 6Last Post: 26th May 2011, 13:02 -
Looking for new driver for video card- MEDION (7134) WDM Video Capture card
By 2prfm.com in forum Capturing and VCRReplies: 3Last Post: 15th Sep 2008, 02:48 -
Do I need a Video Card or a Capture Card...
By gnomeChomsky in forum Capturing and VCRReplies: 14Last Post: 18th Jan 2008, 21:26 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 17:15
