  1. I have a 2.5 hour video that I'd like to be able to get onto one 4.7 gig DVDR. The material was shot in SVideo, so I"m wondering if I can drop that bitrate to accomplish this without a decent decrease in image quality. I'm using Vegas 3.0 and rendering straight to Mpeg2.
    Any ideas? I've monkeyed with the video quality setting and have only saved a few hundred K for my efforts.
    thanks
    -d
    The video bitrate would be around 3mbit/s, you could try lower the resolution to 352x480/576(dvdstandard)...you will lose some sharpness but more bitrate to each pixel which mean less mpeg artifacts. Also try different encoders like tmpgenc, cce.
  3. Thanks Baldrick, love the website and your show!
    -D
    May 2001
    I believe that for 2.5 hours of video (150 minutes) you can use about 4Mbps for encoding and still squeeze it onto a DVD-R. I would encode at full D1 DVD resolution (720 by 480/576) so that you maintain all of your original detail. This amount of video should be no problem at all and will still maintain very high quality.
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    Ohh...I calculated with a 3 hours video....4 mbit should be enough for full d1.
  6. Thanks guys. I love this list!
    -D
