Whats the best DVD player under $150 and plays burned VCDs or burned movies? Thanks
Hey,
If you want cheap, go apex... Wal-Mart has one for 98 bucks, and it will play just about anything...
Matthew -
Look at the list on this site.
APEX players read lots of forms and most can be upgradded.
It seems off brand players are more compatible with home made disks. -
I can reccomend Philips DVD711 but for another reason, the playback picture quality is awesome. The colors come out without biasing to any hue, blacks, whites and mid-tones are totally pure.
I use Titanic DVD as a reference material, there's a certain dark scene with a colorfade. On Philips there's slight steps from one hue to another just barely visible. On some other players that I tested the steps are far more severe.
Philips plays many formats ok (look elsewhere on this forum how I got ff and rew to work for my svcd's should you be interested).
Just My Humble Opinion. -
I had an Apex 703, returned it. A Philips, returned it.
My Pioneer 434 plays everything I throw at it with no problem. Mostly SVCD's burnt with Nero. FF and RW works too.
Excellent player. Good Luck
Need codes to convert Australian DVD player into a multi region DVD player
By Seajacb123 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 13th Oct 2010, 01:00 -
Burned DVD Plays On Laptop, LG Player; Does Not Play On Panasonic Player
By Valentin in forum Authoring (DVD)Replies: 15Last Post: 18th Jul 2010, 12:55 -
Subs work on PC/VLC Player...but don't show up on dvd player
By bgart13 in forum SubtitleReplies: 9Last Post: 22nd Aug 2009, 18:06 -
my player blu ray disk samsung bd-p 1400 not player my avchd on dvd-rw !?
By LEONESVIZZERO in forum DVD & Blu-ray PlayersReplies: 10Last Post: 4th Apr 2008, 09:15 -
How Can I Convert Real Player Video Files To Make Them DVD Player Compatabl
By Lennoxtown in forum Video ConversionReplies: 8Last Post: 17th Oct 2007, 06:05
