Hi
Can anyone tell me whith input and whitch output format i have to use in TMPGEnc? I have several avi´s and wmv´s with different formats. The question is do i have to change the seting in TMPG in order to ovoid "conehads" or squeezed pictures?
Is it right to use "full screen (keep aspect ratio2)"?
diver
use "full screen (keep aspect ratio)" for all, unless you can get away with full screen, if source is almost full screen
Did you work this out by trying it, or are you just good at translating Japanese English? 8)
BTW - a serious question - I'm not being facetious, honest.
Realplayer files to another file format or dvd format
By vieya in forum Video ConversionReplies: 8Last Post: 25th Dec 2009, 13:12 -
Converting raw DV format into a quicktime or MPEG format
By Maiden in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 80Last Post: 27th Apr 2009, 21:00 -
Converting from Flash .flv format to iPod Compatible .mp4 format in ffmpegX
By bananasontoast in forum ffmpegX general discussionReplies: 1Last Post: 3rd Jan 2009, 10:15 -
Converting from DVD format to playable on MAC format...
By livvyramone in forum MacReplies: 2Last Post: 23rd Jul 2008, 09:21 -
Convert Coreldraw file format(cpt) to some other format like tiff
By mysts in forum Off topicReplies: 0Last Post: 31st May 2007, 11:38
