  1. ok so im converting smr movies i do the audio thing then go to encode all looks good i do a 1min test and check it and the video is black i have sound just no pic
    btw im usin TMPGEnc using VideoCD (PAL).mcf template
  2. Banned
    Jun 2001
    UK
    1, Make sure you have the codec, Nimo codec pack has most.
    TMPGEnc
    Select options > environmental settings
    click the VFAPI plug-in tab
    right click the "DirectShow" and select higher priority, do this several times until its at the top with a value of 4
