When I convert the movie Tarzan & Jane, it has no sound for the first 15 minutes or so, then it has both sound and video, but near the end of the movie it has sound but no video. I tried to use different audio tracks, but this ended up being french. Is there a new copy protection scheme disney is using?![]()
I had the same problem on Tarzan and Jane initially using DVD2SVCD. I used the vStrip option instead and works ok. The audio will be out of sync so you have to make modification on the audio delay setting to correct.
LastQuark
TRV900/DV500/CCE/Impression DVD
Premiere/Avisynth/Ricoh 5125A/
DVD2SVCD/RecordNow Max
Cooling Solutions - *Solved & updated* Problems w/overheating & idle temps
By Noahtuck in forum ComputerReplies: 21Last Post: 28th Jul 2010, 21:30 -
Sync problems converting Sex & The City Movie (videora)
By Putana in forum DVD RippingReplies: 0Last Post: 11th Dec 2008, 13:55 -
Converting to B&W
By grandsire02 in forum Newbie / General discussionsReplies: 7Last Post: 10th Nov 2007, 12:29 -
Having Problems converting h.264 mp4 to xvid using avisynth & vdubmod
By Rusty Shackleford in forum Video ConversionReplies: 3Last Post: 8th May 2007, 03:34
