I have a large AVI (4gb) that I have captured.
I want to be able to break it up into smaller clips based on keyframes.
Is there any way of automating this process. ie software that detects the change from 1 frame to another and then splits the avi into different clips.
Its taking me ages to go thru this process manually.![]()
gazza![]()
Vdub is fast anyway
Audio > direct stream copy
Video > direct stream copy
Move to end to get number of frames
2 Split
Goto start, mark start
Goto end frame / 2 (Middle)
Click yellow keyframe back once
mark end
SAVE AVI
Goto end frame / 2
mark start
Goto end
Mark as end
SAVE AVI
FFMpeg - warning: first frame is no keyframe - Encode to nearest keyframe?
By mh2011 in forum EditingReplies: 0Last Post: 3rd Nov 2011, 16:58 -
PowerDirector auto-transition? auto-audio fade?
By yic17 in forum EditingReplies: 1Last Post: 16th Mar 2011, 15:59 -
Media Player Classic: Auto Zoom: Auto Fit logic
By DRP in forum Software PlayingReplies: 0Last Post: 29th Apr 2010, 09:59 -
Keyframe editing not showing up in Vegas 8
By stantheman1976 in forum EditingReplies: 6Last Post: 18th Apr 2008, 07:14 -
Authoring an auto play DVD or editing an exsisting ONE to auto play
By theewizard in forum Authoring (DVD)Replies: 22Last Post: 16th Mar 2008, 12:06
