Hi Guys,
I have a bit of a problem, when I capture from a tv signal, everything works great, avg. fps remains at a steady 25.00xxx, hardly any dropped frames. Maybe 2~4 an hour.
But... now I want to capture from a VHS-tape, which is in a bad shape. I think the tape is physically damaged in a few places. When a damaged part plays, VDub starts dropping frames like mad. Why is this? It thought it didn't matter what was IN the picture, as long as there IS a picture? Or is this some sync issue?
After a few of these 'frame-dropping' scenes, audio is badly out of sync
This is my setup:
HP Vectra VE
P2/400
192 Mb
1x 6 Gb IDE (windows + software)
1x 9 Gb U/W SCSI (for captured avis)
Adaptec 2940 U/W SCSI card
BT484 capture card (Pinnacle PCTV Pro)
Creative SB128 sound card
This combo is fast enough to capture 384x288/44.1xSTx16 movies from a tv-signal, but bad VHS-tapes mess thing up, and even good tapes have slightly more dropped frames than movies captured from tv.
I don't think I will ever capture this damaged tape correctly, but I just would like to know the why....
Thanx in advance for any info
Jeroen
There is really not much difference. The reason your tape capture is dropping frames is due to a weak signal from the old tape. If the capture has trouble reading that frame it drops it and waits for a better signal. A newer tape should give better captures for you.
Your signal from the tv is constant enough for the capture board to get good frame captures.
Anyone has a better answer? Did I answer right?
<font size=-1>[ This Message was edited by: Feslmogh on 2001-08-09 15:41:05 ]</font>
Why is my sig so big?
By hech54 in forum FeedbackReplies: 1Last Post: 28th Apr 2012, 04:14 -
How to Sig-Up to a Thread
By gonwk in forum FeedbackReplies: 4Last Post: 7th Apr 2009, 18:13 -
How much of a difference will vhs picture look on a dvd/vcr combo with hdmi
By fceurich in forum Newbie / General discussionsReplies: 2Last Post: 29th Jan 2008, 13:13 -
Playing VHS through SVHS cable = difference?
By sharper in forum Capturing and VCRReplies: 7Last Post: 17th Sep 2007, 10:56
