Audio stream
Sampling rate 24000hz
channels 2 stereo
sample presision 0-bit
compression unknown (tag 0055)
preload skew 3148 samples (0.13s)
# of frames 36917
min/avg/maz/total frame size 427/584/3148 (21055k)
this is the error i get trying to decompress the audio from a video
the requested audio compression is not compatible with the input format. check that the sampling rate and channel count of the input match those of the requested format.
how do i fix this so i can decompress the audio to encode to vcd the video is a smr
what program are you using to try to encode it?
can't really help much till i know what you are trying to do it with
thru personal experience i have learnt that it's not really worth trying to encode smr releases as the quality is poor to start off with so is only going to degrade more
Backing up Audio CD without compression.
By Bonie81 in forum AudioReplies: 2Last Post: 18th Nov 2010, 12:22 -
YT audio compression
By -Sandro- in forum Video Streaming DownloadingReplies: 0Last Post: 26th Oct 2010, 08:25 -
Audio Compression
By Nitro89 in forum ComputerReplies: 8Last Post: 2nd Oct 2008, 10:00 -
Out of sync Audio; Video Compression?
By Thortok2000 in forum Newbie / General discussionsReplies: 8Last Post: 10th Aug 2007, 12:16 -
Audio compression with VirtualDUb!
By kehn in forum AudioReplies: 5Last Post: 27th Jul 2007, 01:10
