Trying to burn onto CD a "MPEG video/audio stream" file . Tried to convert to BIN/CUE with VCDIMAGERGUI. the VCDEasy.
Am I on the correct track?
What are you trying to do, make a VCD. If so, you cannot just burn the mpeg as data to the disc you need to burn it as a VCD.
Craig -
Craig,
Thanks and yes I am trying to create a VCD from the "MPEG video/audio stream" files.
What is the procedure? I have "Easy CD creator 4"
Manny -
I dont use Easy CD creator as I much prefer nero, but I think you will find that you need the deluxe version, as the standard version does'nt have the option for creating VCD. If I were you I would scrap Easy CD creator and get yourself a copy of nero.
Craig -
Is that the only way? Cant you convert the file and use VCDEasy?
Sorry for the ignorance
Manny
Free software to split large MPEG-PS file into many small MPEG-PS files?
By videonewbie22 in forum Newbie / General discussionsReplies: 9Last Post: 5th Jul 2018, 19:16 -
Choppy playback of some MPEG-2 files and all IFO files
By ANOther1676 in forum Software PlayingReplies: 2Last Post: 8th May 2011, 06:04 -
Convert .mpeg-files to .vob-files?
By stuckinsnow in forum Authoring (DVD)Replies: 1Last Post: 21st Sep 2008, 04:06 -
No audio in powerdvd for mpeg 1 and mpeg 2 files
By Bully9 in forum AudioReplies: 2Last Post: 2nd Jan 2008, 07:23 -
DATA files rather than MPEG files from a DVD-Video?
By DieselsDen in forum Newbie / General discussionsReplies: 11Last Post: 14th Dec 2007, 03:24
