Hi, i bought a hp dvd 100i dvdr/rw, and i basically all i want to do is record my videos from adobe premiere or pinnacle studio dv7, to the dvd's
I have about 3.5 hours of footage right now that i want to get on dvd, it's raw quality format (Straight off dv cam, saved as avi, did this thru windows movie maker i believe)
basically, how the hell should i go about doing this? like 1.5 hours of video was 25 gigs, i think i am supposed to take this video into premiere 6, drag it on the timeline, then create the video using some kinda codec, and then use the burner software to put it on dvd... basically, can u guys gimme a step by step thorough instruction on how i should go about this?
Can i put all 3.5 hours of video onto one single 4.7gb dvd disc? Will i lose quality or anything if the size reduces? Basically, just tell me step by step how i should go about this
thank you all in advance
Hi, guys, i need help with my picture dvd...thanks!
By Lady Colour in forum Authoring (DVD)Replies: 11Last Post: 22nd Dec 2010, 10:46 -
How do you guys convert mpeg-4 file into dvd?
By tendra in forum Video ConversionReplies: 3Last Post: 31st Aug 2010, 01:34 -
How do you guys transfer vhs movies to dvd?
By mmmipa in forum Newbie / General discussionsReplies: 5Last Post: 15th Mar 2008, 16:34 -
Hey can tell me the best performing, most reliable CD/DVD Burner & Medi
By uncleB in forum DVD & Blu-ray WritersReplies: 26Last Post: 8th Feb 2008, 14:22 -
Hey guys, I am new here and I hope I am posting in the correct section ...
By mattarios in forum DVD RippingReplies: 6Last Post: 9th Jun 2007, 21:50
