i have an apex 1200. i can select regions thru the hidden menu. what i am wondering is if i try to play a PAL dvd in my player, will the player convert the signal to ntsc format. what i mean is, will it play ok, in color, on my ntsc tv?
what exactly will it do then. how will the picture look i mean. if it doesn't play well, what's the point?
The picture wont come in. The picture will just keep rolling. Just convert it to NTSC....
how do i do that? you mean convert the dvd to ntsc vcds or something? or is there a better/easier way.
well i would convert it to 24fps progressive and do pulldown on playback .
Look at this: http://www.nerd-out.com/forum/viewtopic.php?t=18559
According to this the 1200 will convert NTSC to PAL and visa-versa with a simple remote control hack. I do not have this player so I cannot personally verify whether or not it works.
PAl to NTSC dvd projects - Conversion
By bpinto0805 in forum Newbie / General discussionsReplies: 1Last Post: 31st May 2009, 03:10 -
FAVC Pal-Ntsc conversion question
By spiritgumm in forum Video ConversionReplies: 4Last Post: 24th Feb 2009, 11:12 -
PAL DVD to NTSC Conversion (read as much as I could)
By DW in forum Video ConversionReplies: 3Last Post: 27th May 2008, 03:42 -
sorry for yet another pal to ntsc conversion question relating high def.
By gearo in forum Video ConversionReplies: 2Last Post: 3rd Nov 2007, 23:20 -
PAL to NTSC DVD Conversion Problem
By squallx404 in forum Newbie / General discussionsReplies: 4Last Post: 8th Oct 2007, 06:16
