  1. I burned a VCD of South Park (3 episodes) and wanted a "menu" but just the four assed monkey, yet when the VCD loads, it shows this rigid image of it but it's diagonal and you get 3/4s of the image on the left side and then the right side has the remaining 1/4th. My DVD player monitor transfer is set on 4:3 PS of course (I don't have widescreen TV...) I followed the guide on creating stills exactly, what's my problem?
    -Bert
  2. Go to http://www.vcdeasy.org and download the update to MJPEGTools and install it. It may fix your problem.
    Regards.
    Michael Tam
    w: Morsels of Evidence
  3. Thank you. But, the link is down (atleast for now it is) and the homepage of the creators is garbage. I tried to download the "package," yet, it just makes you download individual files but it's not even *.zip or *.exe mirrors. Just garbage with extensioins like *.gz and *.rpm and *.deb. I assume those files are meant for putting soley into folders yet the ones already in MJPEGtools are nothing like those, mostly *.dll's... Any other mirros out there you know of? I've tried google/lycos...
    Thanks again
    -Bert
  4. Try www.vcdeasy.org again (it seems to be working now).
    The original MJPEGTools are for Linux/Unix distributions, not Win32.
    Regards.
    Michael Tam
  5. Thanks alot vitualis. I just so happened to check the mirror at around 1pm this afternoon and sure enough I got the d/l prompt.
    -Bert
