Have you tried the following settings on DVD2SVCD.
I have an Athlon XP 1700+ and it encodes around 0.8 to 0.9 with the following. Try for yourself and see what you think ?
DVD2AVI
Lum. Offset(Brightness) =18
(1 Pass VBR encoding seems to produce a darker picture than multipass.)
AUDIO
Audio Bitrate to 224 with downsample from 48 to 44.1
(Miss this out if you want to cut out on some time.)
FRAME SERVER
BicubicResize bvalue=0 cvalue=0.75 (Default)
TemporalSmoother Strength = 4 Radius = 1
BIT RATE
Max=2530 Min=300 (Tick Min Average=1600) Max Avg =2230
(All CD sizes to 800MB) (More or less its the default bit rate settings.)
ENCODER (With CCE 2.50)
One Pass VBR (Tick Create vaf File)
Image Quality Priority = 5
Q.Factor = 5
Tick Anti Noise filter = 10
I'm no confessed expert, but after encoding Shrek, from Multipass VBR x 4 the picture quality looked no worse with the above settings. In fact there was less jumps in the picture. It might not be crisp enough for some perfectionists though ? Looks good on my Sony Wide screen.
	I've encoded Mel Gibsons pay back..
 and The Others - Nicole Kidman
 Had a lip sync problem in the others, but set is to safe frame serving and this seemed to be ok.. Chapter 3 missed out some frames and this set it out of sync ? (Encoding time went from 0.9 to about 0.7) Still quicker than Multi pass.
 I've tried a few guides.. Baker CVD. usual DVD2SVCD stuff.. but the above appears to give good results without multi pass encoding..
 Try it... if you dont like the results.. forget it.
	After trying out my SVCD encodes on my fathers DVD player I dropped the max encode bitrate to 2520, and didnt encode with the advanced function 16:9 anomorphic in DVD2VCD.. Does work with Wharfedale M5 player.. i.e. Wide screen flag..
 Changed DVD2AVI Lum. Brightness to 16 and enabled safe frame encoding on the encoder tab.
 Recently tried Cartoon encoding with CCE..many rookies have found not much joy in this area.
 Surley there must be an acceptable method of encoding to stop the old jaggies ?
 I guess my new born son will just have to watch Walt in Jagger fashion ?
 I'm suprised nobody has written a guide for encoding animation.. Probably due using illegal software perhaps.. Patchers etc.. on CCE...
	Your image quality priority is way too low. You should be using something closer to 22-25. The less bitrate you use the higher image quality priority you need to use or you get mosquito noise.
	Originally Posted by Fred Finkle
 tmpgenc does a better job with animation ... though ive seen some settings for cce that came out vvery nice ,, but generally tmpgenc will do a better job with the animation setting and getting contrast level correct first ..
  Questions regarding recording settings and compression settingsBy so in forum Newbie / General discussionsReplies: 2Last Post: 6th May 2011, 08:45
  DiVX (AVI) to (S)VCD using DVD2SVCDBy LeeBear in forum User guidesReplies: 125Last Post: 4th Jul 2008, 18:01
  Help Please, Error message while using DVD2SVCD and TMPGEnc 2.5By FizzFozz in forum Newbie / General discussionsReplies: 1Last Post: 16th Apr 2008, 17:28
  DVD2SVCD Vista compatibilityBy Kibble in forum DVD RippingReplies: 5Last Post: 19th Mar 2008, 10:51
  DVD2SVCD with CCESP 2.70 - CBR 6kbps? No way around?By Colmino in forum Newbie / General discussionsReplies: 1Last Post: 6th Jan 2008, 01:48
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
