I made something quite large on premiere (25 minutes or so) and I am having problems converting it... I want something that looks good, but is compressed enough to share over net (like under 200 megs) and I want high high quality to put on a vcd. and I want something that's no quality loss to just store on my HD or a cd for backup.
Frame resolution is 352x240
And for some reason premiere is having problems converting to mpeg...
any help?
-Wedge
Use mpeg4 for the compressed one, like divx or wmv.
And you could use huffyuv or just uncompressed avi for the other. -
Hmm, I tried DiVX 5.0.2, but the quality versus size was horrible...
I tried uncompressed avi, that got up well over 15 gigs before I ran out of space...
This is really quite frustrating... I used Dazzle to encode all the source at "movie quality" I'd just be happy if it saved it in the same format as the source material....
Think that is possible?
-Wedge
Can you import from Adobe After Affects to Adobe Premiere Pro?
By Devilsadvocate in forum EditingReplies: 9Last Post: 29th Feb 2012, 21:43 -
Adobe Premiere 1.5: Adobe Media Encoder: Frame size and scaling?
By vid83 in forum EditingReplies: 2Last Post: 30th Nov 2008, 03:17 -
MiniDV to Adobe Premiere to ?
By p3ngu!n in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 16th Sep 2008, 08:10 -
How does Adobe Premiere 2 rate
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 2Last Post: 21st Aug 2007, 23:08 -
help with adobe premiere pro 2.0
By jasonkramer99118 in forum EditingReplies: 1Last Post: 16th Jul 2007, 10:08
