Hello pals,
My operating system is Wini XP and I have about 10GB partition, NTFS, dedicated to capturing. Capturing movies with VirtualDub, using PicVideo codec, via ATI AIW 7200, when capturing in one file, it stops at 2 GB. Spliting the capture into few files, when connecting the fractions later on with VirtualDub, sync is lost between fractions.
Is it possible to capture 1 file larger than 2 GB?
When a movie is captured into few files, how can sync be maintained along all parts?
Thanks.
I`d try using IUvcr, its not to difficult to find on the web, and records in any resolution, in any codec for both audio and video.
I recorded a film directly off sky with it lastnight and it worked like a charm. -
I don't have a AIW but vdub can capture beyond 2 gigs using ntfs. I would double check in vdub settings to make sure that you don't have any time/file size setting that tells vdub to stop. Oh, what drivers are you using for your card? Vfw or WDM?Originally Posted by W_Eagletuco
I like Pinnicle for capture, adobe to.
However adobe produces noise in the left audio channel with my dv-bridge.
They rn't hard to find online, not that i'm encourging u to do that. -
Hello pal,
Did the whole movie went on one file? What is the file size?Originally Posted by Buggerlugs
Take care -
Hello pal,
[quote="tuco1979I don't have a AIW but vdub can capture beyond 2 gigs using ntfs. I would double check in vdub settings to make sure that you don't have any time/file size setting that tells vdub to stop. Oh, what drivers are you using for your card? Vfw or WDM?[/quote]
I Don't know which drivers I use - it's an update from ATI labeled: "wxp-radeon-6-13-10-6071-efg.exe". How can I tell? What difference does it make? What options in VDub should I look at to see whether it's limited?
Take care -
Hello pal,
Is Pinnicle spelled correctly?Originally Posted by Greg12
By Adobe, do you mean Premiere?
Does anyone know whether this sound problem is inherent in Adobe (Premiere), or a specific case?
Take care -
i have had problems with capturing w/ premiere also audio wise .. and this is with a reeltime nitro system and balanced audio off a yamaha digital board ..
i use avi_io most of the time which works very well --
DVDR vs 2GB BDrip
By Vyoam in forum DVD RippingReplies: 29Last Post: 6th Jan 2013, 16:26 -
ffmpeg output 2gb limit? Is there one? ffmpeg stops encoding h264 @ 2gb
By BrainiakZ in forum Video ConversionReplies: 14Last Post: 30th Mar 2011, 13:04 -
Shrink DVD to 2GB or Less
By pandemonium in forum DVD RippingReplies: 18Last Post: 7th Nov 2009, 01:34 -
Which one is better? Shrink 4GB movie to 2GB MPG or 2GB Xvid?
By volam in forum Video ConversionReplies: 4Last Post: 13th Jun 2009, 02:20 -
Converting and splitting 2GB MPG file
By mohalfares in forum Video ConversionReplies: 3Last Post: 2nd Sep 2008, 13:47
