  1. Member wulf109's Avatar
    Jul 2002
    I want to put the episodes two per DVD-R. What is easiest software to create a first play menu so I can select the episode to view? The programs I've looked at seem to complicate the process and don't seem to work from existing vob files .
  2. I put all four on the DVD-R and use the original animated menus and it looks identical to the original! Woo hoo!
    I use:
    DVDDecrypter
    DVD2AVI
    AVIsynth
    CCE 2.50
    Pulldown
    Scenarist
    IFOupdate
    IFOedit
    Nero
    In that order. Get back to me if you want more details. Private message if needed.
  3. Member wulf109's Avatar
    Jul 2002
    Your answer does not address the question. You can't put 8GB on a DVD-R. You are reducing resolution by 50%,that cannot preserve the DVD original resolution.
  4. You are quite correct - I did not answer the question. I put down something that I thought might have been of interest to you, but obviously wasnt.
    BTW, I never said I preserved the original DVD resolution - I said it LOOKED the same (thanks to the efforts of high pass CCE VBR)
    I thought I would put this down as no-one else was replying to your post and I thought you may wish to explore it. That's all.
