  1. Hi, i have an svcd which i cannot play on my dvd player, so i tried the vcd header trick by multiplexing it. The first cd worked fine but the second cd while mulitiplexing stops half way and a messege appears "may cause buffer under flow when played" I've tried different ways of mulitiplexing, i.e de-multiplex then multiplex, the same problem occurs even when i de-multiplex. Can anyone help me out and give me any advice on how to rectify this problem??
    Thanks and any help is greatly appreciated.
  2. hi i've got the same problem with spiderman and scooby doo
    i tried to fix the mpeg files with vcdgear then multiplexed it and it worked, but the problem is at this point where vcdgear fixed the mpeg, audio und viedeo are async
    does anybody has the same problem and can help me out??
