ok i'm not a total n00b, i understand about regions, and i know i can make my apex 1200 region free. my question is if i do this, and i buy a PAL DVD, will it play fine just like an NTSC or will it be like in black & white or something else funky? I've heard that just because a player is region free doesn't mean it plays the discs as good as ntsc. any help would be appreciated.
thanks!
Is your TV compatible with a PAL signal, if not you will get a black and white picture.
Craig -
Correct, just because the player is dual standard (PAL and NTSC) does not mean that it will convert NTSC to PAL, nor PAL to NTSC - it will not. It will only allow you to play NTSC disks on an NTSC TV, or PAL disks on a PAL TV (or else you get black and white, as was mentioned earlier).
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
It's only the way to learn, I never understand this but I check my tv and I can play NTSC and PAL system.. thanks guys for do so much... Gracias..
Hack working for Sony BDP-S380 region 1, to make it region free?
By Julieso in forum DVD & Blu-ray PlayersReplies: 0Last Post: 30th Dec 2011, 16:12 -
Region Free Code for LG DN898--tried hack on site, it didn't work! :c
By lollypopBADgirl in forum DVD & Blu-ray PlayersReplies: 2Last Post: 3rd Mar 2011, 21:17 -
Klipsch CS-500, need to make region free / code free / zone free
By Trialsman in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th Nov 2008, 13:16 -
Bose 3-2-1 region free hack doesnt work see attached keyorder on picture
By monsterag in forum DVD & Blu-ray PlayersReplies: 8Last Post: 27th Jun 2008, 20:46 -
How to Make a Pioneer DVR-520H Region 1 a Region Free player?
By Ossocao in forum DVD & Blu-ray RecordersReplies: 3Last Post: 26th May 2007, 21:35
