That's weird. I rip movie only with DD5.1 sound. Then I author using Maestro and burn using Nero. Everything is OK, but sound level. It's very low. I have to bump up volume on my TV a lot to hear anything. What am I doing wrong?
The real question is how are you playing back the DVD. In DD5.1 most of the sound is in the center channel. Depending on what equipment you are using to playback the sound you might be better off with the DD2 channel sound track or using a full 5.1 decoding and speaker system. If you are using the sound outputs from your PC, and your PC supports 5.1 decoding, be sure you have a center channel speaker connected and not just the usual L & R speakers or all the dialog will be coming out of the speaker you don't have hooked up.
Need suggestions from pros on how to process low-level audio
By Asterra in forum AudioReplies: 2Last Post: 1st Jul 2011, 19:57 -
FFDshow audio decoder level is way too low...
By MidnightMike in forum AudioReplies: 2Last Post: 4th Dec 2010, 00:34 -
Need help with low level hum (audio attached)
By sdsumike619 in forum AudioReplies: 10Last Post: 22nd Aug 2010, 02:34 -
MP3 track - low voice level
By Digiface in forum AudioReplies: 5Last Post: 30th Jul 2007, 17:05 -
LOAD CLICK AND LOW SOUND at join of 2 avi xvid ac3 using vitualdub
By hawklight in forum EditingReplies: 0Last Post: 15th Jul 2007, 08:44
