OK, I'm old and trying to get to grips with new technology, but failing! Could someone tell me what I am doing wrong/not doing at all.
I recently purchased a Cyberhome ADL528 multi-region DVD player which I chose as it could play Video CDs etc.
I use Pinnacle Studio 7 to get movie clips from my camcorder and edit them. I then use the Pinnacle software to save the file as a VCD file (it's one of the options in their software). I save the file onto the hard disk of my computer and then use Adaptec Easy CD Creator to record the Data file onto a writable CD.
The DVD player just says 'Bad Disk'. I've tried different disk makes (philips, Maxel, Trax); I've tried different formats for saving SVCD, MPEG1, MPEG2 etc. I've even taken the DVD player back to the shop and they have put one of their VCD's into it and it worked fine.
What am I doing wrong, please help - thank you.
HiI've even taken the DVD player back to the shop and they have put one of their VCD's into it and it worked fine.
Well hopefully that DVD player does play CDR VCD not just VCD (There is a difference)
It sounds like you have not yet made a VCD, so you need to ensure that the .mpg is fully compliant. Many programs can convert/make mpeg 1 files, but that does not mean they are fully compliant.
In TMPGEnc you can select a VCD template
PAL (UK, Australia, Europe)
Video-CD PAL (MPEG-1 352x288 25fps CBR 1150kbps, Layer-2 44100Hz 224kbps)
NTSC (USA)
Video-CD NTSC (MPEG-1 352x240 29.97fps CBR 1150kbps, Layer-2 44100Hz 224kbps)
Failing to make a VCD with the above specifications, could render the disk useless on your player. Once you have verified it plays compliant VCD's you could move on to see what else it supports.
It is also important to find out what CDR types your DVD player likes, start with HQ disks like Maxell or TDK before trying out cheap ones.
So, does your DVD player play CDR VCD's (Those you make) or commercial VCD's only
You are using VCD in that program ?Adaptec Easy CD Creator to record the Data file onto a writable CD.
There should be a burn template within Easy CD Creator for making a Video CD (VCD). If you are simply taking a VCD compliant MPEG-1 file and burning it as a DATA DISC, then the disc will NOT be recognized as VCD. VCD is more than just a file format, it is also a standard for placing video and other particulars in specific folders on disc. Try using the very same MPEG-1 file in VCDEasy, which you can find through the Tools section of this website. VCDEasy will scan the MPEG-1 file to determine if it is VCD compliant and likely offers more options for authoring VCD than does Easy CD Creator.Originally Posted by clifton
HUN-YA!
Akai Rounin -
I am sure you will, Easy CD Creator (VCD Creator) is very good when there are no problems with the mpeg 1. If there are any problems, it will let you know.Originally Posted by clifton
Conversion & Playing F2V in DVD player
By p_uriel in forum Video ConversionReplies: 2Last Post: 20th Feb 2010, 08:02 -
Need new DVD Player Recommendations Upconvert & RegionFree
By ahhaa in forum DVD & Blu-ray PlayersReplies: 7Last Post: 13th Aug 2009, 11:19 -
Add Text to DVD & CD To Display On Player
By drtalk in forum Newbie / General discussionsReplies: 2Last Post: 8th Mar 2008, 14:35 -
DVD Media & Player Compatibility
By pbisaillon in forum MediaReplies: 14Last Post: 3rd Nov 2007, 18:07
