I finally found a program that converted my svcd (mpg2) video to divx format. Now what I watn to do is put a block over the subtitles using clip frame. What I want to know is what should the settings be in order for me to save this back to svcd format, since the screen size will be differnt since I will be cropping the picture narrower. Here's the info on the file:
51 min. and 19 sec
301,664, kb
480 x 246 29.971
92299 frames
divx 5
keyframs 394
44100
mpeg3
stereo
thanks
Sounds like your converting to DivX to crop, then want to convert back after the crop. Have you tried the crop (Clip frame) in TMPGEnc during conversion SVCD to SVCD . Think the older TMPGEnc 12J is best at this, because of the mpeg 2 support.
I just ran the wizard and used the setting in there, but I did add in noise reduction and quantize martix filter and it looks great.
Best Divx Ultra DVD Player with Full file Names for MP3 and DivX Files
By MCalca1706 in forum DVD & Blu-ray PlayersReplies: 11Last Post: 12th Nov 2008, 13:00 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 14:23 -
Editing w/ TMPGEnc 4.0 Xpress
By JOHNTOUPS in forum EditingReplies: 7Last Post: 20th Feb 2008, 16:27 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07 -
Tool for editing Divx
By ghassan99 in forum EditingReplies: 2Last Post: 18th Jun 2007, 19:02
