I'm trying to install the Adaptec ASPI drivers (4.71) and follwed the instructions exactly. It installed only two files - when I do ASPICHK it says only two files were installed, the other two aren't there - but the readme says this is OK.
VCDEasy says I have ASPI problems and No CD Writer. I have HP200i.
Anybody have any help?
XP Pro
1.8Ghz Pent. 4
512 ram
The Adaptec installation is somewhat of a hassle (and retarded IMHO).
Go to http://www.doom9.org and download ForceASPI. It basically installs the same thing (except it always works).
It definitely works for WinXP as well as Win9x/ME.
Regards.Michael Tam
w: Morsels of Evidence -
By experience, I know that the latest Aspi 4.71 not always work.
Best is to do the "force aspi" and be sure to have aspi 4.69 or 4.70 at your system. This will always work (w9x, wME, wNT4, w2k and wXP) -
Thanks for your help. Downloaded ForceASPI and it worked great the first time around.
STrange that the actual install file doesn't even install all the right files!
Thanks again for your help.
prob joining VOBs; also sync prob with another movie
By spiritgumm in forum EditingReplies: 5Last Post: 19th Jun 2010, 10:32 -
A hardware prob, but what?
By ahhaa in forum ComputerReplies: 3Last Post: 22nd Sep 2009, 22:00 -
Wireless prob?
By Immortal25 in forum ComputerReplies: 4Last Post: 3rd Jun 2009, 08:55 -
ASPI for XP x64
By HartsVideo in forum Video ConversionReplies: 12Last Post: 6th Jul 2008, 05:20 -
gc prob
By Mr anderson in forum ComputerReplies: 6Last Post: 10th Sep 2007, 06:33
