I bought a 5 pack or the Memorex 10x high speed cd-rw's, i burnt off a movie which was 2 parts, on part 1 i burnt it at 10x, and it played fine, i did the same for part 2 and my dvd wouldn't play it, then i burnt it at 8x, same thing...finally worked on 4x, Question 1 is that normal, it not working when burnt at high speeds...I used cdrwin to burn
Later on i went to format the cd-rw's that worked and or the ones that didn't, all 3 of them now give me write cd errors, on format...i'm using nero to format them...Question 2 is that normal, there being errors like that one 3 discs.
I'm using TDK 12x10x32, with burnproof so it isn't underrun
Please help ASAP i need to know so i can return the cd-rw's and if it's my burner's messing things up say so i have a service plan and will gladly change it out for something newer![]()
Results 1 to 13 of 13
Did Nero do a full format or a quick format ?. Maybe you need to use the full format. It does sound like things are not working as they should, but chances of having 3 bad disks is no common.
you'd be surprised...especially with Memorex.Originally Posted by KingJohn
I bought a 25 spindle of their RW's and got 7 bad discs
I wrote them a nasty email, and they sent me 10 new discs...and all of them worked! although one of my original ones that was working just started not to work...even after doing a full erase with Nero
what are you askin' me for...
I'm an idiot! -
No i was using full erase, when i got the errors on there i tried quick just for good measure same results only quicker, as it turns out. If Memorex is that bad are there other brands that are recomended for cd-rw's?
if you can, buy preformatted dics. More expensive but they have
been quality tested. -
Yes it is possible when you buy in bulk spindles, but packs of 10 should be ok. I have used Maxell and TDK since the beginning of time, never once had any problems with them. Maxell are buy 1 get 1 free at the moment here, so I have lotsOriginally Posted by commiewop
16X burn at 24X just fine, also have some TDK I have made at 40X with no problems. Also some TDK CDR-W I burn at 12X for tests VCD's
Have you tried to erase them with another program ? -
I don't know what other programs to use to format other than nero and directcd, but i refuse to install anything adaptec, out of principal, where do you get the TDK cd-rw's, i didn't see any when i was at Best Buy which is where i got the memorex
I just looked a bit for TDK and didn't see High Speed media that's also 700mb, correct me if this is wrong, Then i ask this would it be bad for the cd-rw if it was 4x to burn it at let's say 10x, cause I'm not waiting 22minutes for a SVCD, since i store them on cd-r's and have to make an image then burn -
I just bought a 5pk of Memorex CR-RWs (the 1x - 4x speed type). My burner can go up to 8x, but I thought I would get the 1-4x since I usually burn at a lower speed for quality purposes. But when I put the CD-RW into the drive, the drive doesn't even recognize the disc. I did this for 3 of them. My Memorex 10x CD-RWs work fine. Am I being stupid here???
"If 'Ifs' and 'Buts' were candy and nuts, it'd be Christmas every day..." -
probably not...like I had said, I had a very high percentage of bad discs in my pack of 1x-4x memorex cdrws...send them a nasty email...it worked for me!Originally Posted by emaildavetwhat are you askin' me for...
I'm an idiot! -
Originally Posted by fantomlord
What email address should I use because I am quite steamed. I actually thought that it was my burner or my stupidity.
I THOUGHT that Memorex was a good brand. I would appreciate the email address. Thanks!
I never liked Memorex CD-RWs. Always gave me errors after being formated once or twice. You should try "Verbatim Data Life Plus CD-RW", I have them and they take quite a beating and no errors even with quick formats. Maxell CD-RWs aren't bad either.
TV Respects Me! -
Well the TDK CDR-W I have are 10X so they write just fine at 12X. They were got for me from a local computer shop here in England, they had the 4X only in stock, so I told them I would buy hundreds if they got some. So far I have only bought a fewOriginally Posted by commiewop
I don't see why there should be any problems at a little higher speed. My writer will adjust itself for the strength, maybe that's not available in other writers.
Bitrate question and two pass question
By cyberlion in forum EditingReplies: 17Last Post: 11th Oct 2010, 12:17 -
Help with HF200 (24p and 30p question) technical question
By Coldbricks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 15th Jun 2010, 14:24 -
Mod16 question and DAR question...
By alcOre in forum Newbie / General discussionsReplies: 5Last Post: 31st Oct 2008, 16:18 -
Age old question of VHS to DVD question...I still don't get it.
By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 23:43
