Im restoring my old home videos
they have mono sound, and all the tmpg files I create only have sound coming out of the left speaker
how can i get sound coming out of both speakers?
You could wire both speakers together
... But a better way would be to edit the sound track and copy the left channel to the right. You can load AVI (Sound) into www.goldwave.com and re-save out as stereo.
Or save WAV out in Vdub, then edit with GoldWave. Then use with TMPGEnc for your WAV source.
Vdub
Audio > full processing mode
Audio > compression > PCM (Default)
Audio > conversion > 44.1Khz
SAVE WAV
TMPGEnc also has a stereo setting. -
I use Quicktime Pro on the PC to export audio tracks to 16-bit mono 48KHz (DVD spec), then import that file and export again as 16-bit stereo 48KHz. I don't use the 16-bit mono file because I've had cases where the sound ran twice as fast when playing back a DVD. The resulting file has the sound in both channels.
You might even be able to use Windows Sound recorder to do the channel conversion, but don't use it for bitrate conversion (tinny aliasing effects result).
Lately I've been using an RCA Y-adapter to plug into my camcorder, thus creating two RCA plugs which go into my DV converter box. This avoids the whole export-import-export process.
DVD-R sound coming through only one speaker
By Marshfish in forum Newbie / General discussionsReplies: 5Last Post: 7th Sep 2011, 01:40 -
Edited sound jumps from speaker to speaker
By len hend in forum AudioReplies: 3Last Post: 23rd Jul 2010, 05:49 -
Video + mono -> Video + Left & Right audio dubbing
By mmafan in forum Newbie / General discussionsReplies: 7Last Post: 17th May 2010, 17:35 -
Help: Sound only plays from left speaker
By rdc in forum AudioReplies: 5Last Post: 31st Dec 2007, 21:25 -
Converting a Mono Left Channel to Double Mono Left/ Right Channel on a DVD
By socool135 in forum AudioReplies: 5Last Post: 16th Sep 2007, 00:45
