I have a question before i buy a DVD burner....
Can you burn the whole entire DVD including the EXACT same menu, extras, etc. I know it depends on the size, but im planing to burn DVD's that dont have much features just the movies itself, trailers, etc.
For example im planing to burn movies like Titanic, Menace 2 Society, etc.. the ones with hardly any extras at all.
You can do this but it requires some work.
There are some guides on doing that. It mainly involves ripping all the unwanted extra stuff out and using ifoedit. The only problem with the titles you sugested is the size of the files. Titanic is well ... "HUGE" and would probably require 2 dvd-r's.
Koops
Simple question on DVD+R DL discs/Capacity
By alegator in forum MediaReplies: 12Last Post: 19th May 2011, 04:52 -
simple question for experienced DVD player owners
By asmodeus718 in forum Newbie / General discussionsReplies: 4Last Post: 3rd Apr 2010, 22:02 -
Adding extra material to the end of a simple 1 movie dvd (with simple menu)
By ColinKe in forum Authoring (DVD)Replies: 4Last Post: 24th Jul 2009, 22:38 -
AviAddXSubs simple question (hopefully!)
By vladman2nd in forum SubtitleReplies: 1Last Post: 8th Jul 2008, 01:01 -
Simple Mplayer Question
By Maikeru-sama in forum Newbie / General discussionsReplies: 6Last Post: 29th May 2008, 21:10
