When I try to use TMPGENC to convert an avi file to Mpeg1(vcd), captured with Premiere 6, I get file could not be opened or unsupported format. The issue is that the file plays just fine on windows media player.
I am running XP pro and feeling quite frustrated. The file was captured with the following specs:
32 KHz
16 bit stereo.
Any help would be appreciated
If you can load it into Virtual Dub, you can frameserve it to TMPGEnc. Or save it once you do load it into VDub. then you should be able to open it in TMPGEnc.
Hello.
Need help converting H.264 from Samsung cam to MPEG-2/DVD
By moxiecat in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 1st Mar 2010, 16:00 -
Problems converting AVI to vcd format using TMPGenc 2.5 Plus
By peterock in forum Video ConversionReplies: 2Last Post: 28th Dec 2008, 15:34 -
Converting AVI using TMPGenc = No Sound?
By CaptainChaos in forum Video ConversionReplies: 2Last Post: 16th Dec 2008, 16:12 -
Loading footage captured on DV tape, shot with HDV cam??
By Anthalloran in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 8th May 2008, 10:04 -
converting from mpeg1 to divx
By mlkwestcoast in forum Video ConversionReplies: 3Last Post: 21st Dec 2007, 11:09
