My PC DVD drive has finally died after 3years hard labour, it was well overdue a replacement anyways.
Can anyone recomend a decent replacement, theres so many to choose from
Require : Standard DVD ROM (not a writer)
Budget : £50
Any tips or advice would be much appreciated.......
cheers
Geeee THX............what a friendly bunch you all are.........the last time I think I will bother posting on these forums
they're all basically very similar really.
if you're up for it and installing it yourself, try the samsung. You can get this from www.blankdiscshop.co.uk for £25 plus postage (probably £3.99 in addition).
you can blow your remaining 20 quid on a couple of films then!Mantisgeek -
Thx mantis.......at least someone can spare 5mins to help a n00b out.
Ill check that link u gave me
The current Samsung DVD drives offer the best bang for the buck
in my limited experience, and can be flashed to region free (as can others.)
Recommendations Please, Blu-ray Player with USB HDD support
By Hollywood_12 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 21st Mar 2012, 17:53 -
Need some guidenace or recommendations
By TwoMutts in forum Media Center PC / MediaCentersReplies: 2Last Post: 8th Feb 2010, 19:42 -
software recommendations
By deftones in forum EditingReplies: 3Last Post: 12th Nov 2009, 20:33 -
Need Standalone Recommendations
By Thadius856 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 16th May 2008, 08:52 -
I am looking for recommendations
By Tidy in forum DVD & Blu-ray WritersReplies: 5Last Post: 8th Jan 2008, 13:48
