using the sefy allinone guide, which step lets you add subtitles???? i cant find that step?
Have you tried this link?
http://www.vcdhelp.com/edit.htm#subs -
thanks i could probably use that for some video but heres what i was trying to ask//// if the subtitle feature is turned off for a dvd they will still come up if someone is talking chinese or something...those are the subtitles i am talking about ...like if i were copying the star wars trilogy vcd, jabba the hut talking in huttese or whatever would still show up as subtitles on the bottom even if subtitles were turned off.... do you understand? those are the subtitles i am talking about
But are not those subtitles part of the movie? They are even seen on the VHSes as I recall. They cannot be turned off, and will appear whether you have selected subtitles on or off, no?
Hello. -
no.. at least not always. For example see The Mummy. TheOriginally Posted by Tommyknocker
egyptian dialog is a secondary subtitle. You can turn it off
in some players. -
In the "All-In-One" guide, you can use DVDx / FlaskMPEG or the frameserving method with VirtualDub in order to create a movie with subs
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician.
ffmpegX burned subtitles are missing with arabic (iso-8859-6) subtitles
By eswenson in forum ffmpegX general discussionReplies: 6Last Post: 11th Jan 2012, 09:22 -
DVD software player- raise subtitles to top of scrn/ simultaneous subtitles
By jimdagys in forum Software PlayingReplies: 8Last Post: 6th Dec 2009, 18:30 -
Converting AVI to DVD plus Subtitles (Loss of quality on subtitles)
By somenho in forum ffmpegX general discussionReplies: 2Last Post: 27th Aug 2009, 10:23 -
Burning .mkv file with .ass subtitles to DVD WITH the subtitles
By isfjinfj in forum Authoring (DVD)Replies: 2Last Post: 23rd Jun 2009, 17:28 -
Help with converting DVB subtitles to idx/vob subtitles
By Talayero in forum SubtitleReplies: 8Last Post: 21st Feb 2009, 18:10
