When trying to use tmpgenc 12a to reencode a dazzle DVC2 mpeg2 capture I select the file from the browse button for video source. In the video and audio boxes is displayed "mux//filepath" instead of simply the filepath. When I select encode, tmpgenc seems to just remux the files instead of actually reencoding them (it just takes a couple of minutes for a 1hr clip at 480x480 2650vbr) and the resultant file properties are the same as the original regardless of the template I choose. Although I do use this mux function to create nero compliant files, I'd like to sometimes be able to reencode the mpeg to change bitrates, etc.I do have the vfapi plugins and ran the install.bat file.
I've tried tmpgenc12i and the files are "unsupported" although it did work, once.
Anyway to reliably do an mpeg reencode?
It's been a while now, with no solution after repeated efforts.
...maybe HELLLLP SEFY!! any ideas on this??
BTW, I have the run vfp-install.bat and have appropriate vfapi-plugins installed, have either/both powerdvd and windvd2000 installed. Attempted w/ win98se, w2k and me.
And what causes this curious "mux://C:\*" pseudo encode?
Just delete the "mux//" part people. That should solve the problem. It's apparently a syntactical shortcut that TMPGEnc provides to allow multiplexing without using the multiplex dialog under MPEG tools.
To make the problem go away permanently, you might try disabling the "Enable multiplex with "mux://file name" for video/audio source" option found under the "Options | Environmental Settings..." menu. -
just deleting the mux part won't work, tmpgenc can not accept mpg2s as inputs. you'll have to run the mpg2 file through dvd2avi, then use the d2v file as your video input source. hence the reason why to convert a svcd -> vcd, you have to go through dvd2avi.
A couple of questions for the experts?
By Rumdaddy in forum Newbie / General discussionsReplies: 6Last Post: 22nd Sep 2011, 12:54 -
Any final fantasy 13 experts here?
By yoda313 in forum Off topicReplies: 3Last Post: 1st Jan 2011, 08:54 -
HDI Dune 3.0 experts
By neworldman in forum Media Center PC / MediaCentersReplies: 3Last Post: 16th Sep 2010, 14:54 -
TMPGenc DVD Author Experts
By Maikeru-sama in forum Video ConversionReplies: 4Last Post: 26th Sep 2008, 18:33 -
Nero experts, need some help
By vitamine in forum ComputerReplies: 2Last Post: 15th Dec 2007, 16:42
