hi all
i've been experimenting with getting my svcd onto dvdr, the only sucessful method i have come accross is to convert the svcd to dvd mepg, but i've been tryin to use the method off vcdhelp, svcdonto dvdr, i cannot for the life of me get that program spruce to work correctly for me... is there any other program that will allow me to import and patched svcd and mpa audio file... i can do everyhting in the guide until i come to authoring bit of which the guide only uses spruceup.. amd evereytime i use spruce i load up the files, it doesnt seem to find any contents of which i have just loaded, i've had enough of spruce...
ok. I have just finally gotten "a" method of doing this to work for me sucessfully.
The method I used was.
1. Convert using tmpgenc. I used the wizard so that I could estimate the best bitrate that would maximise the space on the dvd.
2. Used Ulead DVD Movie factory to create a udf.iso file.
3. Burnt this to dvd-r using instantcd+dvd via the wizard "burn a udf iso image".
Home video 8.4GB on Dual Layer DVDr want to put on 2 4.7gb dvdr ??
By rockonvidtrade in forum Authoring (DVD)Replies: 11Last Post: 19th Oct 2013, 23:25 -
DVD to AVI/DVDR and AVI/WMV/MOV to DVDR
By BIFFtheSTIFF in forum MacReplies: 5Last Post: 19th Nov 2010, 12:35 -
What device will enable recording of TV to DVDR and DVD or VHS to DVDR?
By enricomad in forum DVD RippingReplies: 1Last Post: 26th Jun 2008, 17:46 -
PAL DVDR to NTSC DVDR including menus + extras? Is there an easy way?
By junkmonk in forum Video ConversionReplies: 3Last Post: 13th Mar 2008, 23:19 -
Apple Trailers to HD-DVD or BluRay on a standard DVDR/DVDR-DL
By Scooter_NJ in forum Video ConversionReplies: 0Last Post: 21st Feb 2008, 18:14
