Hi
Having probs with getting this working on my laptop (PIII 1Ghz, WinXP Pro 256meg ram). WinTV2000 loads ok, but the picture freezes after about 15 seconds and the red light on the WinTV USB goes out. Prog doesn't freeze, exit it and start it again and it does the same.
If the channel viewed is a crap reception, it's fine, but change to a good quality reception tv channel, it stops.
Any ideas? (latest drivers tried etc)
Thanks!
Results 1 to 1 of 1
Which is better quality capture- DVD recorder or Hauppauge WinTV USB stick?
By akalsha in forum Capturing and VCRReplies: 9Last Post: 6th Mar 2012, 18:57 -
Which hdtv's have a USB port, so you can plug in a flash drive or USB HDD?
By snafubaby in forum DVB / IPTVReplies: 8Last Post: 30th Nov 2010, 16:03 -
Question about deleting USB drivers to fix lack of USB notification
By jimdagys in forum ComputerReplies: 13Last Post: 15th May 2010, 10:24 -
Hauppauge WinTV 2Go capture card was Kworld DVD Maker USB 2.0
By Vampire74 in forum Capturing and VCRReplies: 4Last Post: 19th Jan 2008, 09:59 -
Can a usb mass storage mp3 player and usb harddrive coexist in vista?
By yoda313 in forum Off topicReplies: 3Last Post: 5th Aug 2007, 18:23
