Using CDMage I extracted an SVCD Bin/Cue file for Spiderman SVCD Screener. I opened up DVD WorkShop and loaded the AVSEQ1.MPG file (CD1-3) that I extracted. I saved, then burned my project onto a blank DVD. It burned, but for some reason the audio of the movie is out of sync. In the preview option in DVD Workshop it played normally, but when I burnt it again on another blank, the audio was of of sync.WHY![/url]
The SVCD audio is most likely 44.1 Khz, while the DVD standard requires 48Khz. Hopefully, DVD Workshop is re-encoding the audio for you. Do you have version 1.2? People have reported audio sync problems with version 1.0. If this doesn't work, you can use TMPGenc to demux the audio track, transcode it to 48Khz, then remux it back. This may provide better syncing than DVD workshop. Let us know how it works out!
How do I make an edited compilation of several different commercial DVDs?
By WileE in forum EditingReplies: 8Last Post: 27th Nov 2010, 20:33 -
how do i make copys of dvds
By MATTBARR in forum DVD RippingReplies: 1Last Post: 15th Jan 2008, 15:07 -
Does iDVD make standard format DVDs (file structure-wise?)
By Scav2003 in forum MacReplies: 2Last Post: 5th Nov 2007, 02:11 -
How do you make menus for dvds....
By mmmipa in forum Newbie / General discussionsReplies: 1Last Post: 2nd Nov 2007, 13:33 -
how to make a dvd from 2 or more different dvds with menu and subs??
By vinayak1986 in forum Authoring (DVD)Replies: 1Last Post: 9th Sep 2007, 02:59
