I had a Sony TRV27 miniDVcam and I'm trying to pass through from my DVD to the PC but I receive a copyright notice in the camera display. The manual says "you cannot record or capture the video output ...that include copyright protection signals such as the ID-2 system". There is anyway to Hack this ?
You don't need a hack. If you are using the passthrough correctly (i.e. not recording onto tape but sending the signal directly to the computer through a firewire cable), most capturing software will not detect this ID-2 protection. The only software that I know that detects this protection is the Sony provided software.
If you have no other capturing software, you can use DVIO or amcap (freeware programs) which do not detect ID-2. -
The copyright notice came from the camcorder and not from the software, so i guess the protection is before it arrive to the software. I don't know... I can try that app. to see what happen. Thanks
Tommyboy -
I forgot to mention, make sure that "DV out" is enabled on your miniDV camcorder (select it from your camcorder's menu).
Copyright and Child Protection when videoing
By IKnowNothing in forum Newbie / General discussionsReplies: 4Last Post: 24th Jun 2011, 10:23 -
Sony RDR-HX750 Stopping for copyright
By rtimboz in forum DVD & Blu-ray PlayersReplies: 4Last Post: 5th Jun 2008, 14:42 -
Panasonic DMR ES20 . copyright protection? CPRM? FR mode no pause etc
By texas1 in forum DVD & Blu-ray RecordersReplies: 8Last Post: 2nd Mar 2008, 14:10 -
key exchange for dvd copyright protection
By repeatrepeat in forum Newbie / General discussionsReplies: 6Last Post: 26th Aug 2007, 00:54 -
VHS Copyright protection
By demonwarrior in forum Newbie / General discussionsReplies: 1Last Post: 22nd Aug 2007, 06:57
