I captured a television program using the Picvideo MJPEG video codec, and the MPEG Layer 3 audio codec with the intent to compress with DivX. As the movie progresses, the audio and video get out of sync. I followed the guide on how to fix sync. It suggested to convert my captured .AVI to .MPG, and split to the audio and video. After converting the file to .MPG, I noticed that the audio and video were no longer desynced. Please note, I did nothing to fix the audio/video sync problem, it seemed to fix itself after the conversion to .MPG.
After deciding that the hand of god has fallen upon me (Anyone know what the real explanation of this is?), I decided to convert the .MPG to divx. After reviewing the divx file, the audio/video sync problem was fixed, but I decided that the video quality was unacceptable.
Then I tried converting directly from the capture file to divx, and although the quality was much better, the audio and video were still out of sync. Anyone know how I can get the audio/video in sync, and retain the original quality of the capture.
Thanks!
You probably shouldn't compress the audio on it's way in during the capture, and do all your compression following the initial capture.
I am guessing you're getting out of synch due to your hardware not being able to keep up.~~~Spidey~~~
"Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards
Mov audio/video sync problem
By adabo in forum EditingReplies: 7Last Post: 28th Jun 2018, 12:09 -
Audio video sync problem
By FrankieToh in forum Newbie / General discussionsReplies: 0Last Post: 3rd Dec 2010, 07:53 -
HELP! Trying to capture s-video and digital audio and sync them.
By laureynsr in forum Capturing and VCRReplies: 7Last Post: 24th Dec 2008, 21:56 -
Audio Video Sync problem
By m baqar in forum Authoring (DVD)Replies: 1Last Post: 27th Mar 2008, 00:59 -
Audio/video sync problem
By Hekey Williams in forum DVD RippingReplies: 1Last Post: 8th Oct 2007, 04:27
