I have been trying to burn a movie I got from ng's. When I try to drop it into VCDEasy I select the file but nothing happens. I was able to burn with Nero at a SVCD. Haven't had anything like this happen in the last 2 months of using VCDEasy.
Thanx
flatlyne2001
Did you uncheck the "Perform MPG Complience Checks" box? Maybe something is wrong with it. Uncheck the box and then try to load it.
Others have reported problems related to their ASPI layer and Windows XP. I have no idea what OS you're using. I would suggest trying possibly a different version of VCDEasy or possibly looking at your ASPI layer. Beyond that I really don't have any other ideas. Keep trying.
Yes I am on XP imagine that. I actually only use VCDEasy so that I can entrypoint/chapter my SVCD's. VCDEasy says that my ASPI is fine, and I haven't installed anything new lately either. I guess I'll just keep trying to figure something out.
Thanks all
MPEG won't import after converting using VOB2MPG
By olweiser in forum Video ConversionReplies: 3Last Post: 20th Aug 2010, 12:44 -
MPEG Streamclip won't open DVD
By shakes1327 in forum MacReplies: 2Last Post: 7th Mar 2009, 09:54 -
WMP/MPC won't play any mpeg video
By hhhgamewmx7 in forum Software PlayingReplies: 3Last Post: 20th Feb 2008, 10:36 -
VCD MPEG playing won't work in WMP11...
By fabvideohelp in forum Software PlayingReplies: 6Last Post: 22nd Nov 2007, 12:25 -
Win Media Player won't playback mpeg video
By Borgatt in forum Software PlayingReplies: 5Last Post: 21st Jun 2007, 02:46
